Old 02-16-2011   #11
So they would've covered this under warranty if it needed it? Or if it still will need it? (which hopefully it won't)
Yes, it appears so.
So transfer cases howl and whine when fluid comes out? That is odd...
So nothing was replaced as well? Im guessing you just stopped the car because of the noise?
Odd indeed, but they have test-driven it and say it's making no abnormal noises. I will test-drive to confirm before taking it home. It is good knowing everything was documented (including the factory drain/fill plugs being untouched since the factory) in case something occurs down the road...at least these things have 60k mile warranties.
