Old 02-24-2011   #5
Leviathan
Drives: Sik Whips
Re: Just rebuilt the motor, terrible idle on startup
You can have boost leaks at and after the throttle body. Those are the ones that screw things up the most.
Do you a datalogger for it to see if some sensor is reading totally wrong?
I don't have a data logger unfortunately. I have a friend with a Genisys scanner who may have OBD I hookups. I'll try that tomorrow. After driving it today it seemed to idle better. Meaning it will idle for a second or two before dying off. If I don't see anything crazy from the sensors I'll check into leaks around the throttlebody, injector o-rings, and any other vacuum source I can think of.
Leviathan is offline   Reply With Quote
