Old 03-07-2011   #5
Perkul8r
Perkul8r's Avatar
Drives: 91 GVR4
Re: Using AEM UEGO to simulate narrow band O2
From what I have read, the Uego has a 0-5v output that can be configured. According to their website..
I got this straight from their install quide, but I do have to look at my unit again. Cause it does not look like the one in the pic.
Configuring Calibration Outputs
If a different O2 sensor calibration is desired, the AEM calibration can be changed to
one of three available. The AEM default position is (P0) if an AFR Gauge was
purchased and (P1) if a Lambda Gauge was purchased. These settings implement a
linear calibration with the most useful voltage range possible (0-5V). The AFR
calibration (P2) is linear and similar to (P1) with a slightly smaller voltage range (1-2V).
The AFR calibration (P3) emulates the Autronic Wideband O2 Sensor calibration (0-1V).
The AFR calibration (P4) emulates a non-linear Nernst Cell calibration (0-1V). Refer to
the Table and Graph for specific calibration details.
