Old 09-04-2012   #1
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Mark's 1G Winter Projects
How'd ya do at MC shootout?
Old 09-04-2012   #2
Mark Leasure
Mark Leasure's Avatar
I did sport compact a disservice last weekend. Showing how this really sucks to try to keep a car running when it’s an import. My first pass I had a set screw loosen up on my throttle body and when I floored the accelerator pedal to get on the two step the car went to idle…. Pass #2 rev the car up, and start slipping clutch, bam broke the freshly installed upgraded transfer case from Boostin Performance…Fuck Fuck Fuck, 1200.00 dollars down the drain, 5-10 feet. Fucking garbage, my luck sucks. I put the factory case back in that I ran at the map event and keep in mind this is my last chance at qualifying, rolled off the line free reving the car and ran a 9.7 @ 153. Got DQ’s for being too light. Car with me, passenger seat with belts weighed in at 2780 and needed to be 2850. This means that I have the car down to 2540-2550 range without me and my safety gear.
The upside is that I pulled the parachute, which is totally awesome! To prove it was a street car they do a cruise around the race track for 4 laps, super fun running down the straights at 40+ pounds of boost! My wife screamed every time I got into the boost, super funny, she is screaming on video that she was shooting of the cruise.
The car is running great, all the fueling issues are worked out now thanks to MAP helping me out with swapping out the 2150’s. Over all it was a great weekend, makes me want to run a V8 car with turbos. People running tractor T88 old school turbos, running 8’s all weekend , weighting 4000+ pounds, with 15 psi of boost was sickening.
www.maperformance.com
Old 09-04-2012   #3
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Thats sucks! Cool to hear about the weight though. Im sure it takes a ton of patience and money to get a 4 cyl in the 9s.
Old 09-04-2012   #4
You see Jesse Nelsons giant 4000+ lbs chevelle running 8s with ease at low boost.
Makes me want one.
I'm sure your luck will change soon enough, sucks you had to pay that much for a T-case to not even get a pass out of it.
Old 09-05-2012   #5
Wow, I think they'd be getting an earful from me if that happened. Good luck getting it back on the road.
Old 09-05-2012   #6
Lookin' good!
Old 09-16-2012   #7
Mark Leasure
I removed my instrument cluster and installed my dual range tach. I also installed a AEM serial gauge. The serial gauge is awesome showing more functions that what I had. Programming was not for the novice, but I have it showing multiple different functions, like battery voltage, water temp, wideband, fuel pressure, boost, and speed ect.
Old 09-16-2012   #8
Time to put a chevy duramax xfer case in that thing!
Old 09-16-2012   #9
Shitty luck on the xfer case situation man. At least you got to make a run and have some fun with it!
Don't sweat the boosted v8's, it's all relative.
Old 09-17-2012   #10
Mark Leasure
Yeah, I have cut my best 60's and 1/4 mile mph and times on a stock case. Just some bad luck on the upgraded ones.
Old 09-25-2012   #11
Mark Leasure
Making some side mirror deletes out of fiberglass. I want them to cosmetically look good and be easily removable so I can install the factory in minutes. Should be a fun little project. Anyone know a painter that could finish paint these once I'm done?
Old 09-28-2012   #12
Old 10-04-2012   #13
Mark Leasure
Side mirror deletes are done.
Old 09-17-2012   #14
2G.S.X.
2G.S.X.'s Avatar
Drives: 2G GSX Eagle/Wiseco Hi-Comp. 6bolt, Evo III 16G
I've always wondered why no one makes an aluminum exhaust system. Good to see that it can be done. Looks great btw. (I realize that it's old news, but my first time seeing it.) As for the rest of the thread, omfg, holy shit, and jfc. Great Work man!! That's a pretty df amazing 1G. Oh and I was just curios what gauge that Al. tubing is, and how is it holding up?
2G.S.X. is offline   Reply With Quote
Old 09-17-2012   #15
There are a lot of people with AL exhaust, I think mark is the only local, for now.
Old 09-17-2012   #16
Mark Leasure
Running aluminum exhaust can be a pain in the ass. I have it on my Evo and the Talon. I have broken both systems, and the breakage is at just about the same point too. I think I have most of the weak points fixed and the welds are reinforced where the aluminum connects to the SS down pipe. I have 3K miles on the evo now with no issues since the repair. I’m sure over time I will have other issues, owning a tig welder comes in handy! I don’t recall the gauge, I think 16?
Old 09-25-2012   #17
I got a friend that is a painter, just tell him they are plates about the size of where the mirror bolts up?
In black?
Shoot me a PM with info so not to clutter your thread.
Old 09-25-2012   #18
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Carbon wrap the deletes. Would look sick.
Old 09-25-2012   #19
Mark,
We are good enough friends I hope you can take some constructive criticism....those mirror deletes look like piss. Seriously you might as well just cover the hole in painters tape, it might look better!
Old 09-26-2012   #20
Mark Leasure
Mark,
I love you like a sister scheides.
