Old 06-06-2012   #1
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Mark's 1G Winter Projects
Nice! glad to see you're still planning on rocking the 1G at the PG!
-Sebastian Vettel
Old 06-06-2012   #2
Awesome. Good luck those GSC S3s are sick, you should be happy with those.
I hope you get more than one clean pass.
Old 06-06-2012   #3
Damn that sucks your t-case puked on you. Good luck at BIR.
Old 06-06-2012   #4
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Good luck!!!
I also picked up those cams so it will be good to hear what you think. Obviously my setup isnt the exact same but still cool to see what I can expect.
Old 06-06-2012   #5
mondale
Drives: 1g dsm
Good luck!!!
Copious amounts of airflow lol.
8.59 @ 158
mondale is offline   Reply With Quote
Old 06-07-2012   #6
santa
Boost Spike
santa's Avatar
If you need a lap top holder for those wot pulls, im your guy!! Good luck Mark!! Hopefully we can line up against each other and confuse everyone which car is which!!
Old 06-08-2012   #7
Mark Leasure
Mark Leasure's Avatar
Sounds good to me! How's your car coming along?
Old 06-08-2012   #8
santa
Boost Spike
santa's Avatar
Driving it up to map in a few minutes to have the nhra chassis inspector check it out. Hopefully it should pass with flying colors. Let me know if you need a hand with your car!
Old 06-09-2012   #9
Mark Leasure
Good thing I decided to do a cam swap, I found 3 of the 5 nuts on my adjustable cam gears were finger tight. The shield plate that attaches to the head had one of the small fasteners ready to fall out. Who knows another couple of miles and the whole motor could have been F’d. Now the cam gears have Locktite Red applied.
The idle is a little rougher, not too bad though. You can physically see the difference in the cams when you set them side by side with the S3’s. The S3’s are monsters. I wish I could have done them when I built the motor, since I’m a little concerned about valve to piston clearance. I’m just going to let her buck and see what happens. I took the car around the block in front wheel drive mode and the tires break free at about 15 psi making the care useless. Now I know why transfer cases take so much abuse, it’s like the front have no aid in the traction department. These 1G’s are closer to rear wheel drives.
Now I just need to get the transfer case in it and tune it up, should be exciting!
Old 06-09-2012   #10
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Woo! Good to see a few cars getting ready for proving grounds! I'm excited to see you and Kevin both make some passes in this year. We have to have some fast cars around here, seems there's quite a few really quick 1g's nationwide this year.
Old 06-11-2012   #11
Most after market pistons have enough room with a 1mm over valve.
Old 06-11-2012   #12
Mark Leasure
Good to know John, I took a compression check after I smoked the front tires to almost 8k. All is good!
Old 06-14-2012   #13
Mark Leasure
I took out the broken transfer case and replaced it with a factory one. Now it's just a matter of some tuning and an oil change to get the new cams dialed in.
Pic of the broken case:
Old 06-14-2012   #14
Because Racecar.
Old 06-14-2012   #15
HOLY
Glad you are getting it all taken care of though
Old 06-15-2012   #16
I think you need one of these haha
Old 06-15-2012   #17
He needs the race version fool!
That thing is $350!
Old 06-15-2012   #18
Did you run a raspberry shake for fluid in your tcase?
Old 06-15-2012   #19
I remember splitting the front of my case in half at the shootout, but mine wasn't nearly that bad. You know you're supposed to get out of it when smoke and parts start flying out, don't you?
Old 06-15-2012   #20
Mark Leasure
All tuned up! I did a roll on in second gear and spun the tires super bad. I tried again in third and the tires spun a little at 7800 RPM! This was on a flat entrance ramp with the QTP’s on it! It has never spun 3rd gear, ever. The spool is a little slower, from what I can tell about 200 RPM. It makes 40 psi by 6200 RPM from a 3rd roll on. I also raised the rev limiter to 9.5K. It’s been awhile since I drove it so it’s hard to tell from my memory if it’s faster. The only thing I could do is to compare a 3rd gear roll on run from last year. It is 0.45 seconds faster from 6K RPM to 8.5K RPM. With 3 psi less boost too. Hopefully the lazier spool will make for a little less of a violent launch off of the line and save the drive train a little. I’m now 100% excited to see if I can beat my personal best MPH and time, right off of the trailer!
