View Poll Results: Block color?!
Semi-gloss black 5 100.00%
Green "Metallics" *pics of can posted* 0 0%
Cummins beige 0 0%
Purple 0 0%
Cast Iron 0 0%
Metallic Gold 0 0%
Paint By Numbers 0 0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 03-24-2011   #11
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: 95 Talon TSi AWD
Good Thread.
Go with the HX40 on that 2.3L Spools very quick as it is. Also, you're gonna want to make sure you follow the Holset's specs for installation. The off the shelf drain tube kits are way too small. (14mm). Holset requires at minimum 19mm ID. I modified a drain tube from a 2001 Cummins Dodge Ram, used -16AN Pushlock hose to slip over it, and welded a nipple on my oil pan in the factory spot.
Ok thanks. That'll help down the road.
