View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 04-04-2011   #11
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Kind of a dammed if you do dammed if you don't troubleshooting method but rod knock will go away if you pull the injector plug for the cylinder with a spun bearing. Basically start the car, pull the coil or injector plug for each cylinder.
Also rod knock is most pronounced when you let off of 2000-3000 revs, unless the bearing is absolute toast and knocks all the time. It will be sound very rythmik.
Flywheel bolts are a possibility. Had it happen to me on my 2.4 builds and if you would have heard CornFed 2.4's talon (my old talon) this past summer when a flywheel bolt came loose, you would have swore it was motor. It was awful, ask Aaron.
If I can help. let me know.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
