Old 04-17-2011   #1
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Project Winter Beater
Painted the stealth wheels I got from Ryan last year. Also painted and installed a little piece from my Laser on the front:
Had to remove the muffler I welded on. Noticed the inside had fallen apart and was just floppin' around inside the muffler. So, back to straight pipe:
Still daily driving it, and the car has been running great.... aside from a little crack in the I/C. Good thing I'm in blow-through configuration. Car also handles amazing with these tires and the new e3 16g power. I get lift-off oversteer, and throttle on oversteer whenever I want. I'm very excited for autox season to start.
I'm also adding power steering to it:
I don't have fluid in it yet so the belt is not on either. I have to get the cooler mounted and plumbed yet, so I don't want to make a mess and waste fluid.
My alternator went out a few weeks back so I bought a 90 amp gvr4 alt. from work (oreilly's), made a little heat sheild that bolts to the o2 housing, and installed a volt gauge where the cig lighter use to be.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-20-2011   #2
123abc
123abc's Avatar
Drives: Loud cars
Well I started putting fluid in and the belt on Sunday. Everything was going good until I look under the car and sure enough, there's a big puddle. I push it in the garage and jack it up. Turns out this line, number MB501433, was rusted through right where it runs through the rack mount on the passenger side.
I undo the sway bar and take the rack mount off that side and luckily I'm able to get a compression fitting to work. So far it's been holding...
