Old 05-30-2011   #1
cman3000
Colin
cman3000's Avatar
100m Running Champion!
Drives: 90 Talon TSi AWD, 73 Datsun 240z w/Built L28
Re: ECMLink Tuning Questions (Logs Included)
http://www.jeffgst.com/e85global.html
That is where I am getting the equation from.
Also here
http://www.ecmtuning.com/wiki/baseinjectordata?s=e85
In the table at the bottom you will see it says ~-20 for 880s on e85
cman3000 is offline   Reply With Quote
Old 05-30-2011   #2
Also here
Flip it to 31% and check, otherwise if you dont believe andrew, post it up on the link forums. they will likely say the same thing.
The reason your car is running like ass is that your fuel trims are not set properly to the global value you set. Doesnt ECMLink have some kind of thing where you tell Tom Dorris what you have and he will send you updated settings, or some kind of autotune thing? I thought this was part of the V3 updates.
Old 05-31-2011   #3
cman3000
Colin
cman3000's Avatar
I will try it today and see how it goes. It wasn't that I did not believe him, I was just setting it based on everything that I had read. I am not sure about sending Tom my info, and I have no idea where to check on this. I am running V2 with the ECMlink software, so if it is only something for users with V3 hardware, I may be out of luck.
Old 05-31-2011   #4
Well if you PM Tom on the dsmlink forums or just make a thread on the tuning forum, state exactly what you have, and ask what your base settings for e85 should be, they will be able to help im sure.
Old 05-31-2011   #5
General rule of tuning: go with what works on your car, not what is published on the internet (although it can be helpful starting point)
Old 05-31-2011   #6
cman3000
Colin
cman3000's Avatar
Thanks for the responses guys. I set it to 31 and the AFRest is now a lot closer to what the wideband is showing. My problem now is that the car is stuck in open loop. Causes of that? Could I have fouled out my front O2? I can get it to cycle during cruise at some points, but during idle the car shows 0 on all trims and O2 will not cycle. I have adjusted the BISS, played with the MAFcomp settings, and double checked my fuel pressure(with vac line off).
