Old 06-07-2004   #9
white 2g awd
Send a message via AIM to white 2g awd
i haven't checked the coolant yet, but with a blown head gasket, wouldn't the compression be worse since it was blown??? and i know its leaking tons of oil, my oil return is leaking a little bit, i will have mitsu check that tomorrow though, and i had them put in some new spark plugs and spark plug wires today, cause they were the only ones in des moines that had any of either in stock. i hope it's not a blown head gasket, most boost i've ever run on thsi was 19psi with my evo 16g that i have now. thanks for the help, also, do you think that this injector could be the problem, it kinda seems logical to me, cause the mitsu guy said it was spraying all the time, that it was just stuck open, and every time this happens i can't start my car, i pop the hood, and i can smell the gas, in the engine bay, like its not getting burned, does this sound right? thanks for your help.
Dustin
white 2g awd is offline   Reply With Quote
