Old 07-19-2011   #3
Re: Tuning for higher base fuel pressure
Just make sure your fuel flow (volume) is acceptable at the higher baseline pressure. As fuel pressure increases, fuel pump volume decreases and if you are in fact at the limit of your pump AND your injectors, you will be pissing into the wind.
