Old 08-12-2011   #8
Re: Need help with tuning
If you are on the stock 450s, then you shouldn't have to do anything. If should run fine with a stock tune. That closed loop error could be caused by a bad o2 sensor, a boost/vacuum leak, bad coolant temp sensor reading.
