Old 08-19-2011   #2
Chim55117
Drives: 2007 BMW 335i Coupe
Re: The Return of 46/1000
Finished up the car, brought it home last night. No leaks, needs a tune badly. School starts for me on Monday, so I'm off to school (in state) soon. Going to park it behind my brother's other VR-4 until I'm ready to tune it.
Still need to schedule a tune with Shane, and would like to make it to the Mitsu Cookout, but I guess we'll have to see.
Looking for 500-550WHP.
1992 Mitsubishi Galant VR-4: 46/1000
Modifications
Engine -
Shortblock:
8.5:1 Mahle Pistons
Eagle H Beam Rods
ACL Main Bearings
ACL Rod Bearings
ARP Main Studs
Head:
Lightly Ported Intake/Exhaust Ports
Brian Crower 272 Camshafts
Supertech Dual TI Beehive Valve Springs and Retainers
A1 Technologies L19 Headstuds
FelPro PermaTorque MLS Headgasket
Exhaust:
Primo Performance Modified V-Band O2 Housing
Tial 38MM Wastegate
FP Race Manifold
Forge Blow Off Valve
Intake:
Holset HX-40 7-Blade
GM Blow-Through MAF
MAF Translator
Cooling:
Mishimoto 3-Core Civic Half-Size Radiator
12" SPAL Fan
2.5" Thick Intercooler Core with Primo Intercooler Piping
1990 Oil Filter Housing to 1G Air Oil Cooler
N/T Water Pipe
Fuel:
FIC 1600CC Injectors
Dual Walbro 255LPH Fuel Pumps
NRG AFPR
-6 AN Braided Fuel Feed Line
Ignition:
Tayor 10MM Wires
NGK BPR7ES Spark Plugs
Electronics:
Socketed Eprom ECU with DSMLink V2.5
ProSport 52MM Mechanical Boost Gauge
HKS Turbo Timer
Driveline:
Competition Stage IV Street Clutch
ACT Streetlite Flywheel
1G T/E/L Short Shifter
Brass CNC Shifter Cable Bushings
Aluminum CNC Drive Shaft Bushings
Prothane Polyurethane Motor Mount Bushings
Suspension & Brakes:
Rebuilt Suspension with Energy Suspension Bushings
Stainless Steel Brake Lines (Front and Rear)
PowerSlot Rotors
Hawk EBC Green Pads
3000GT "Big Brake" Calipers
Suspension Techniques Rear Sway Bar
KSport Kontrol Pro Coilovers
4 Bolt Rear Differential
DSM 5 Lug Conversion
Interior:
Evo VIII Front and Rear Seats
Grant GT Steering Wheel
Polk Audio Speakers
Infiniti Amplifier
Exterior:
Metallic Gray Hyundai Valve Cover
Enkei RPF1's 17x8.5's with Yokohama P235/45R17s
JDM VR-4 Front Bumper
'91 JDM Grille with AWS/4WD Badge
'93 USDM Headlights with Phillips BlueVision Bulbs
Pre-Facelift EDM E39A Corner Markers
JDM RS Projector Foglights
Smoked '89 UDSM Style Rear Tail Lights
Miscellaneous:
Catalytic Converter Eliminated
Cruise Control Eliminated
Emissions Eliminated
A/C Eliminated
Balance Shafts Eliminated
"We are what we repeatedly do. Excellence then is not an act but a habit." — Aristotle
Chim55117 is offline   Reply With Quote
