Old 06-12-2004   #1
Enes
Enes's Avatar
Well here is list of my setup
50 trim
550cc rc injectors
190whinebro
ported 2g exhaust mani
external wg
2 1/2dp
3 catback
factory cat
gredy large fmic
type s bov
maft
bpr7 sparkplugs
magnecore wires
1g intake cam gear 2g one got bent..
just did timing belt job and balance shaft elim
no boost leaks
18psi of boost
pump gas
3 counts of knock at 7300rpm
only made 260whp
i need your opinions what could be wrong with my car... i will be going thru the whole engine bay to see if i am having something unpluged or a vacum line since i only get 15 for vacum at idle, and it used to be 18 before
I can't adjust my base timing since its a 2g... but i will check it today with the light
i'll check compression today too
but i need your suggestions what else i would need to check..
i made 260+ last year on t28 without ported mani and balance shafts removed..
-E
-E
