Old 10-06-2011   #11
Re: after 10 years its coming back to life
been working on it the last 2 days. It is getting there.
got the fmic put on and started to put the a/c system back in the car
also took out all the abs wiring out of the engine bay harness and put it back in the car. Also did a mini tuck with it. I used the 3 holes that were in the frame rail and make 3 brackets to bolt the fuse box in the wheel wheel.
fuse box bolted into its new home
I drilled out the spot welds on the stock lower radiator brackets and made some new ones and welded them in so I could use my 1g fludine radiator in the car
