Old 12-12-2011   #8
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Winter plans/mods 2011
I'll need to pull the engine to drill out the 2 center bearing bracket bolts on the drive shaft I sheered off. Then I should probably rebuild my prop shaft as it's making quite a racket since installing solid bushings. I also need to replace the seals on my power steering rack... they finally gave up the ghost after 21 years.
For fun stuff, I've got fully poly bushings for the rear end, including the moustache brace. I also am planning on lighter 17x9 wheels with 255 wide rubber on all 4 corners.
-Sebastian Vettel
