Old 03-24-2012   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: Mark's Evo IX MR Winter Projects
Originally Posted by Mark Leasure View Post
Yep, it was MAP. There is a drum deposit charge tacked on too, so yes the fuel comes with the barrel. I would only use it if you need to, 98 percent of people only need 85. Unless you have a setup that is capable of sky high boost, like 40+psi then 98 provides a knock safety factor.
Assuming we have the good E85, not winter blend crap. I like the idea of mixing e98 with 93 octane to make e85.
