View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 04-06-2012   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Wtf are they talking about? It's the timing cover that leaks. Just pull off the acc belt and pulleys (you know how to do this now!) and unbolt the cover. Clean and apply fresh RTV and re-assemble.
It is def a PITA job but not 14 hours as you do not have to pull the head, just about a billion little bolts holding the cover in place.
Unless the leak is coming from somewhere else?
I don't think its the actual timing cover, unless I misunderstood. They said the timing cover has to come off and the head to seal this leak. He said something about two little tabs that stick out on the back of the motor and you need to RTV them and one of those is leaking or something.
Obviously before I do anything I will try to figure out what they were talking about, but regardless, still something is leaking.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
