Old 04-10-2012   #11
Re: Mark's 1G Winter Projects
I run Crower 288's (stage 4). They are degreed in on a 111 deg lobe separation. Max lift I .415" E .398".
With your 2.3 9500rpm and big turbo you will want the biggest cams that will fit. Motors are air pumps and if you can not get air in/out you will be hard pressed to make power.
Idle and down low throttle will suffer but the extra power is worth it.
It would be cool to see your 1g dyno graph overlaid with my car from the dyno day last year.
