Old 04-17-2012   #19
Dizmm
Dizmm's Avatar
Drives: on ICE
Re: Crankcase ventilation
If you use a real catch can, you will have no issues with anything getting back into the intake.
David, search dsmtuners for calan and his catch can and I promise you will be happy with the results. Hell I'm buying another one soon.
the other problem you have with doing large crankcase ports routed to a catch can, then routed to the intake, is you will significantly alter the metered are by the MAF. If you are running the stock size port from the valve cover, you can get away with it.
Andy Smedegard
Dizmm is offline   Reply With Quote
