Old 05-07-2012   #11
Re: Project V8killa
The stock fuel lines should be fine. The bottle neck will be the banjo bolt coming out of the filter. Getting a new feedline that ditches that banjo bolt should be enough, I'd just run -6. For more reassurance you could upgrade to a higher flowing filter while you are at it too. That's how I ran with my 62mm setup, worked just fine and isn't too rough on the wallet.
