Old 05-10-2012   #11
Re: beaterX project thread
Not a bad garage-rigged solution! You could probably cut it down a bit to allow some of the fresh snorkel air to the filter, but while still blocking the A/C fan air.
That's the thing, the issue I'm seeing now is that air from the snorkel itself is affecting my AFRs on the street. The faster the car is going, the more turbulence is hitting the MAF, and unfortunately its causing my AFRs to go lean
The way I figure, this shield will block that direct blast of air but still let the snorkel's fresh air still fill all the area around the filter.
