Old 05-16-2012   #33
Yiddie
Yiddie's Avatar
Drives: 98GSX
Re: Serious Issue
Hooked up a scan tool today. Adjusted the tps to 0%.. air/fuel is a little better not 100% idle is sitting at 12.8-13.2 and cruising its at 14.8-15.2... ideal would be idle n cruise to be 14.2-14.6. Still gotta do a boost leak test and I did not install the bypass plate yet. My tuner told me idle should be at 5% so after I do a blt I'll adjust the tps to 5% n see what happens. Scan tool only shows % not volts. O2 sensor and maf sensor seemed be to okay also.
