View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 05-31-2012   #11
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Originally Posted by simulatedwood View Post
I guess my point was that, you have something in the system saying it is running lean, but it is not running lean, then you have an feedback issue to sort out. If you know the injectors are fine, and your running consistent fuel pressure numbers (has this been verified?), then I don't see how this isn't a sensor issue of some sort.
When the car I was troubleshooting had ground issues the sensor readings were all over the map (o2, MAP, and TPS), this caused a ton of CEL's, but the car ran, OK. At time the idle would die, sometimes surge, sometimes engine ran lean, etc. Spent money on a MAP and o2 sensor that didn't need to replacement, but all the signs said they were failing. As it turns out, just needed to replace the ground wires going to and from the chassis to the engine and all was right with the world, sensor readings made sense and the car ran awesome.
I actually am running lean right now...1-3 gears are like 17 afrs at cruise then when I get going a bit more the AFR's get to where they should be, 14-15.5 area. But the car is struggling to run a bit when its running lean lean. I am not boosting what so ever, this is just running around honda civic style too. It's hard to say whats going on.
The idle fuel pressure has been verified, once the car is in gear not sure as the fuel pressure gauge is in the engine bay. I'd need to get the car on the dyno to know.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
