Old 08-22-2012   #1
timschot
timschot's Avatar
Drives: 2008 Evo GSR
Re: looking at Evo's. Few Questions.
If you are staying stock turbo and run out of fuel, it's easy to address anyway. It takes 30 minutes to swap and hardwire a better fuel pump and injectors are right in the front of the engine bay if you're going e85.
timschot is offline   Reply With Quote
Old 08-22-2012   #2
No reason to hardwire an aftermarket fuel pump until that pump, and any larger single pump, can't support your requirements. The 9/12v switch is a nice feature to keep the pump from overrunning the stock FPR at idle/cruise, and also helps keep the pump quieter and cooler, which should ultimately lead to a longer lifespan.
Old 08-22-2012   #3
timschot
timschot's Avatar
Good points. I am on a hardwired dw300 running e85 though and have not had idle or cruise issues, but I've only done 4-5 tanks so far and have no idea what my fuel pressure is at. I have heard of people pushing return lines off fittings, but mostly on pump. The car is getting another round of mods shortly though, so I might need to revisit.
