Old 08-26-2012   #5
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: no spark
You obviously missed something... You check the wiring between the cam sensor and ECU? Check the wiring between the transistor and ECU?
Does the coil pack have power?
The fuel pump will turn on when you turn the key on to prime. But does it continue to run while cranking the engine? Pull the cam sensor out and spin it by hand and listen for injectors to click, fuel pump to run, or coil pack to fire.
Originally Posted by shoutbox
