Old 08-30-2012   #21
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: no spark
No... It cannot be anything other than what I stated... If the cam sensor works when its out of the engine, but does not work when its installed in the engine.
It would either be the cam sensor or the cam!
Go check what I told you to check. It has to be one of those 4 things...
How could the ecu all of a sudden stop working when you put the cam sensor in the head? But as soon as you pull the cam sensor and spin it by hand, it starts to work again? Use your brain man. If you are not willing to at least check what is suggested, then dont ask for help.
Originally Posted by shoutbox
