Old 09-19-2012   #4
Re: boost control
If you don't use error correction then you can probably do it without a map sensor. It might be hard to tune and dial in though without some datalogged boost though. The DSMs and EVOs stock don't use a map sensor for ecu controlled boost control, they use calculated load instead, but DSMLink wants to work off a boost value. If you don't use error correction though, then it should just run the duty cycle you say.
