Old 10-06-2012   #13
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: Self defense round recommendations?
You don't know me, so I'm sure you'll take my advice with a big grain of salt, which is good.
When it comes to my .45 handguns I exclusively use FMJ rounds. Why? Several reasons.
1. Cost. I like to train with the ammunition I'm actually going to use. So why buy expensive JHP rounds? This is more important than it seems as some .45 handguns have a tendency to have fail to feed issues with hollow points. Especially 1911's. So if my gun carry *might* experience a FTF I'm going to want to put hundreds and hundreds of rounds of my carry ammo thru it to make sure it's not going to happen.
2. Penetration through drywall etc. A FMJ round and JHP round of the same power are going to be nearly equal here because a standard JHP round generally isn't going to expand in drywall. So pretty much a moot point there. Don't ever think that JHP wont over-penetrate indoors.
3. Penetration through flesh. .45 is a big slow round and this means 2 things: first know that the biggest factor in whether or not a JHP round expands inside a target is velocity. I've seen tests where very high priced .45 JHP rounds only expanded about half the time, and extremely cheap 7.62x25 rounds (a very fast pistol caliber) expanded every single time. So the question is, is that JHP even going to expand? Maybe. Does it matter? well, if the FMJ round doesn't come out the other side of the target either, then no, it didn't really matter.
That's my opinion anyway. That said when I carry a 9mm I carry exclusively with JHP rounds. This is because 9mm is faster, which means the HP is more likely to open up AND a FMJ is more likely to over-penetrate the target.
