Old 10-08-2012   #11
Re: MitsuStyle Fall 2012 cruise - October 6 & 7 - Superior, WI
I heard no honks. Cam should have just stayed in it, I was in the throttle.
Other thing to note is that I was making more than normal up top, I can feel the car pulling low end timing but it's running what it should above 5k, and with the temps where they were I was seeing 29psi peak in 4th. Oops.
Why would you not run 29psi? You should be running as much as that thing can make!
