Old 11-06-2012   #18
Re: New Short Block
$7500 yeow! Penny pinch man, penny pinch. I saved $$ on my motor build by doing as much myself as I felt comfortable with but it still bit me in the butt in a few spots.
I'm down with the full stage1 setup, good solid motor setup. Clean up the head. Pray none of the valves are bent--I had 6 bent IIRC and it cost me a pretty penny to fix. Send the cams AND valve tappets with to the machine shop as I wasted probably TEN days waiting for stupid new tappets and other misc delays....anyways strap it down with standard ARP headstuds torqued with a good solid torque wrench, don't forget the little oil filter screen that sits on the top of the block.
More spots I saved cash on:
The gasket kit--listed as $310 above idk what's in it so I just ordered peice-by-piece from mitsu (looked back at my notes for this) for $121.85:
intake manifold
headgasket
head-to-waterpump
head-to-tstat housing
turbo coolant hose (mine was a little iffy)
turbo drain-to-block o-ring
4x oil filter housing-to-oil cooler copper washers
This leaves room for cheapo o'reily 10w30 oil for break-in, coolant, a small pile of oil filters and a fresh set of plugs.
That reminds me, I have lomker's HKS spark plugs to use during your break-in if you want....no big boost on them but you can do all the vacuum pulls you want on them and then swap in a set of fresshie gapped plugs once you're ready to tune.
Also I put in a fresh clutch disc in for my HDG6 to give it some extra life for something super cheap like $150.
I'll post up anythign else I can think of.
Also be SMART and don't go more than a few miles once you get it back together without double and maybe triple-checking ALL fluids in the car--engine oil, coolant, trans fluid, xfer case fluid, brake fluid, clutch fluid. I see people turn a blind eye to this shit...if you had a hand in assembly or not be smart and check these!
