Old 11-27-2012   #1
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: From ashes
You can raise the base fuel pressure and get more out of them. The ID1000s work very well at higher fuel pressures. But ID1000s on on E85 are maxed at about 360awhp on my dyno on E85. I have had numerous Subarus run out even before then due to their fuel pump wiring and not so efficient motors.
360? Hmmm, that sucks.
My Dw1000's made 420 on your dyno on e85 with my fpred...360 is surprisingly low.
I know many people have had decent luck with the fic1100's and I have never heard too many bad things about them and i have seen people with FPreds on E85 not run out of fuel with them but after reading that stuff posted it seems that the FIC stuff isn't engineered/tested very thoroughly.
As my setup "works" with the DW1300's I am not going to switch unless its for quality/reliability and if their is any doubt with the FIC, I think its safe to say no one questions ID that I have ever seen so they are the logical choice.
Old 11-27-2012   #2
Re: From ashes
From the threads it seems that no one needs to question ID as of yet, as they seem like they know their shit and have been detailed in their approach to testing.
Old 11-27-2012   #3
Re: From ashes
1000s usually max at 400-410 on E85 my dyno, but everyone always want to run shit at 100% and make the most power versus leaving some headroom, so fuel pumps and injectors are often running maxed out, and calculated injector duty cycles in loggers like Evoscan are not close to accurate due to the Mitsu ECUs not actually supplying that data. The difference between running 11.0:1 and 12.0:1 is a decent amount of fuel also and the difference between E70 and E85 is also quite a bit of fuel.
I have had STI's max the ID1000s on E85 at around 340awhp.
