Old 01-16-2013   #11
4seasons69
4seasons69's Avatar
Re: Rebuilding motor, need suggestions
My old talon burned quite a bit of oil but never seemed to smoke that I noticed. I would say maybe double check the compression with a differ gauge just to make sure there's nothing wrong with the gauge. Then try a wet compression test and do a leak down test. The variance between the highest and lowest cylinder is quite a bit. So it still seems like something is not right. Generally you don't want more than a 20% difference between the highest and lowest cylinder
