Old 01-30-2013   #16
blackrosenova400
blackrosenova400's Avatar
Re: this looks to good to be true, has it been proven?
Originally Posted by M1L3S View Post
was it hard to set everything up and make it work together ? I have no ac etc.( I mean tune wise ) dis the intake make a well worth it difference?
1g throttle body bolt right up ?
1g throttle body bolts right up. I run speed density with an evo 8 ecu. If your running speed density it will have to be tuned. If your running a maf sensor it should be able to pick up the extra airflow and relay to the ecu alot better.
Yes I do see a nice extra airflow chunk down low
20g Mafia
