Old 11-07-2003   #6
Originally posted by FORSFED@Nov 6 2003, 10:23 PM
Can anyone think of what would cause too much fuel on a stock car?Â* I've narrowed the problem (high rpm misfire) with my car down to this, but can't figure out why.Â*
I know this is the case for 2 reasons::
1.Â* leaned out afc and problem went away but was too lean so I adjusted back
2.Â* disconnected vac line to fpr and plugged it.Â* went for ride and no problem except was lean again.
Fuel related, I've replaced the filter and fpr and ran a bottle of redline cleaner through the tank.Â* Now what should I be checking?
oversized injectors without any fuel management
bad MAF
leaking/sticking injector/s
dirty air filter
restricted fuel return line to the tank
BOOST LEAKS/metered air not making in into the cylinders
You say you leaned it down and the problem went away, but it was too lean, so you put it back? If that fixed the problem which had to put it at the correct mixture, why would you say it was too lean, it was probably correct?
Is the vacuum line for the FPR coming off of the correct port? It should be connected to a direct manifold vacuum source.
