View Poll Results: How much WHP will I make on Cobb's AWD Mustang dyno?
<450 2 11.11%
450-475 3 16.67%
475-500 6 33.33%
500-525 3 16.67%
525-550 3 16.67%
>550 1 5.56%
Voters: 18. You may not vote on this poll
Old 02-18-2013   #281
Re: SE take two! Err, make that three!
sucks about the clutch. I bet its a spring rolling around in there.
Old 02-18-2013   #282
We should know for sure in short order here. COBB wants him to go with a 3-port BCS instead of the MBC for dyno tuning so a Grimspeed will be added shortly here too.
I told him to also look into the CM FX350 clutch material as well; it seems to be a new upgrade vs. the FX300.
Old 02-18-2013   #283
Can he just keep his pressure plate then and just swap out disks?
Old 02-18-2013   #284
We reused the pressure plate & flywheel this time around, but it all depends on if there's any damage once we pull it apart.
Old 02-18-2013   #285
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
For how cheap that clutch is and the hassle of pulling the transmission out, I'd say replace both, but hey maybe drinking beers while working on his car is like a relaxation thing down there
Old 02-18-2013   #286
If it were me, I would never reuse anything, but not my car, money, nor choice I am going to petition for everything (complete clutch kit & flywheel friction ring) to be replaced this time around to avoid any unnecessary failures.
Old 03-03-2013   #287
Any update?
Old 03-04-2013   #288
More clutch problems...got the tranny back on Saturday only to have to take it off again on Sunday. We're fukkin pros at unclipping the TOB now.
Dyno tune with COBB is scheduled for Saturday 3/23 at 9am so we have about 2 1/2 weeks to get it running and finish break-in.
Old 03-04-2013   #289
Oh man. Still running a FX400 or whatever it was?
Old 03-04-2013   #290
Tachyon
Tachyon's Avatar
Drives: Icarus
Hey, at least you have nice weather for your tranny activities.
I was all amped to work on my car on Sunday... went out to the garage in 30 degree weather, NOPE, and went back inside.
-Sebastian Vettel
Old 03-04-2013   #291
LOL this has been me a couple times this winter.
Old 03-04-2013   #292
Yup, it's not the clutch itself though. As far as I can tell, the CM discs are high quality and their PP's are just modified stock Exedy.
Old 03-04-2013   #293
Mid-80's today!!!
Old 03-04-2013   #294
Tachyon
Tachyon's Avatar
Drives: Icarus
Mid-80's today!!!
#$*&@#^&@#$%! STOP IT!
-Sebastian Vettel
Old 03-04-2013   #295
QFT!
Man, if this wasn't a car forum....
http://mitsustyle.com/forums/showthread.php?t=32634
Old 03-05-2013   #296
New clutch setup on the way: CCI Stage 3.5 segmented ceramic clutch and CCI 10.8lb flywheel.
Old 03-05-2013   #297
3.5? So is that like a stg 3 disk and a stg 4 pressure plate?
Old 03-05-2013   #298
Stage 3 is what I had in my IX which is segmented Kevlar, this is a step up in power holding with segmented ceramic, but will be more streetable than the Stage 4 ceramic 6-puck. All CCI clutch kits for the 8/9/X now include their 3000lb HD pressure plate.
Long story short, the CM FX300 disc he bought isn't compatible with the PP from his CM FX400 kit, and his FX400 disc is defective with a loose hub. Going the CCI route was the quickest thing possible since MAP had it all in stock while Andrew waits for CM to inspect and replace his FX400 disc, which will then be sold with the matching PP and TOB. So, if anyway wants a brand new CM FX400 disc with barely used PP and new TOB...
Old 03-05-2013   #299
Gotcha. Sounds like a nice combo!
Old 03-05-2013   #300
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Thats the clutch I just got in my car, love it so far.
2006 WW IX RS 396/404 - SOLD
Tags
post liked by shane
