Old 02-23-2013   #11
Mark Leasure
Mark Leasure's Avatar
Re: Mark's 1G Winter Projects
I received my clutch last week with a number of other goodies from DSM Graveyard, new timing belt covers and windshield cowl. The clutch is super rowdy! It’s all set up and I will be dropping in the motor this weekend. I also installed a 12 tooth crank trigger wheel from Kiggley. It should make for some rock solid timing. 1G’s are timed off of the CAS vs the crank shaft. There are way too many things that can go wrong with the CAS setups with high horsepower DSM’s. The kit Kiggley send has all the correct fasteners to attach the crank sensor wiring and routing so it clears the timing belt, I admit it looks a little precarious.
www.maperformance.com
