Old 06-05-2013   #181
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: Carl's 98 auto AWD project Black Magic
I got some valves ill give ya a bunch so you'll have back ups.
Old 06-05-2013   #182
Well at least it stopped there and didn't chew up the piston/cylinder wall! That is crazy dude, definitely one for the books!
Get this thing fixed asap!
Old 06-05-2013   #183
The car has been running good for the last month or so. I even drove it to Brainard lastwweekend and it was a smooth trip. Yesterday it desired to remind me that it was a DSM. It took. It into town and on the way back it started to misfire. After looking at it for a few hours I found that it threw a rocker on one of the intake valves. I think the lifter collapsed and allowed the rocker to eject during a pull I made right before the misfiring started. There is a slight scratch on the cam lobe, but no other real damage I am planning on replacing the lifter and and putting the rocker back in, and hoping for the best.
So the car didn't self destruct?
Old 06-05-2013   #184
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
No I'll take the blame on this one, even though I have no idea how the clamp got in there. It just seams like a DSM to be running perfect one minute the drop a cylinder the next. The car ran for over 600 miles with the clamp in the motor So I guess these DSMs are pretty badass.
11.35 @ 120mph
Old 06-05-2013   #185
Tachyon
Tachyon's Avatar
Drives: Icarus
Indeed. Frankly I think they are some of the best engineered cars from that era when you think of what we are asking out of the original design parameters.
-Sebastian Vettel
Old 06-11-2013   #186
carltalon
carltalon's Avatar
I got the car all back together last night and it its running good again. I replaced the two valves (thanks Cornfed) cleaned up a few small dings in the head and the top of the piston and put it back together with new gaskets.
while it was apart I took the oppertunity to coat my exhaust manifold with the extream high temp header coating I got from Ling ling. I had my buddy that did all my powder coating sandblast the manifold, paint it and cure it in his oven. it turned out so good it was a shame to cover it with the heat shield.
Now I just need to fix my coolent temp sensor pig tail that has a loose pin in it and get my drag radials mounted and I will be ready for proving grounds.
11.35 @ 120mph
Old 06-11-2013   #187
Got a nice sized crack on the bottom side of the manifold.
Old 06-11-2013   #188
Old 06-11-2013   #189
Nice job getting it back up and running so quickly!
Old 06-11-2013   #190
carltalon
carltalon's Avatar
Yeah I think that's been there for awhile. It doesn't go all the way through. The coating just makes it stand out. Mabey some day I'll step up to a FP manifold..
11.35 @ 120mph
Old 06-11-2013   #191
Just wait for a holiday sale! haha
Old 06-11-2013   #192
HAWT! Nice work man! So you didn't have to machine the head or anything, just slap new valves in? If so that's nutzo!
Old 06-11-2013   #193
carltalon
carltalon's Avatar
The seats had no visable damage. I think the seats held up because they are harder then the clamp was. I lapped in the new valves and they lapped in really nice. I rechecked the seats after lapping the valves and they were lapped in evenly so I figured I'd run it.
11.35 @ 120mph
Old 06-11-2013   #194
Tachyon
Tachyon's Avatar
Drives: Icarus
That's amazing O.O
-Sebastian Vettel
Old 06-12-2013   #195
lol nice to hear its back together.
Manifold looks good, even with the surface crack.
Old 06-12-2013   #196
Old 06-23-2013   #197
carltalon
carltalon's Avatar
The day started out kinda ruff but got better at the end. After waiting fot the rain to clear out and getting no practice/ qualifying passes. I got disqualified the first round of eliminations. Because the car wouldn't make boost at the line so I took to long to stage. I Waited around and watched the rest of eliminations hoping they would have open testing after. They did so I made 3 passes first was 11.64@ 116mph I followed that up with 2 11.7s @ 117mph. All in all I consider it a good day since I drove the car there and back and raced with no issues. It was good seeing other members up there I will try to do better at PG13.2.
On a side note. Bald guys need the. Apply a 2nd coat of sun screen if they are going to drive home with the sunroof open. My head hurts.
11.35 @ 120mph
Old 06-23-2013   #198
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Looked good going down the track wish I could of lined up with ya.
Old 06-23-2013   #199
carltalon
carltalon's Avatar
Next time.
11.35 @ 120mph
Old 06-23-2013   #200
Car was looking good, it was a bummer you got kicked out the first run.
You went up there nick? You bring the car?
