Old 03-06-2013   #101
Re: From ashes
Yeah that curve wants to keep going, rev that bish to 9k!
Old 03-06-2013   #102
Trogdor
Trogdor's Avatar
Drives: people crazy
Re: From ashes
That EF3 is supposed to be good for 650. BAP would be the next step. But not sure that I'll end up getting around to that for a while. I'm quite happy with where its at.
Old 03-06-2013   #103
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: From ashes
550 bobby not 650
2006 WW IX RS 396/404 - SOLD
Old 03-06-2013   #104
timschot
timschot's Avatar
Drives: 2008 Evo GSR
Re: From ashes
Do the return line siphon drill mod before you put a BAP on there (see my post on evomn). Your W400 should already be flowing as much as my dw65c with BAP does I would think.
But great numbers anyway!
2008 GSR SSS WW
RS motors built
454/388 mustang dyno on winter E70
ERL sleeved block, MAP rods, Wiseco pistons, MAP EF3, Exedy Twin HD
timschot is offline   Reply With Quote
Old 03-07-2013   #105
Re: From ashes
Oh, I missed that you went with a W400 already. I am shocked that it is out of fuel. Is it the e85 version? Do you have a fuel pressure gauge at all? Its possible your base fuel pressure is off the map and severely limiting the flow of the pump.
Old 03-07-2013   #106
Trogdor
Trogdor's Avatar
Re: From ashes
Yeah, I saw the link. Going to ask Ron about that. Thanks Tim.
Yup
I have no idea what that even means. But no, I don't have a pressure gauge.
Old 03-07-2013   #107
Re: From ashes
Study up on how fuel pumps work. The higher the pressure they are pumping against, the less overall they will flow. Restrictions in the fuel system can lead to this.
Go back in my project thread about a year and you'll see all of my W400 shenanigans including fuel rail and siphon drilling. I actually bent my stock FPR to reduce base fuel pressure while installing a boomba fuel rail. Lots of fuel capacity on my setup now
Drilling the siphon is pretty easy, it takes about 20 minutes to get the fuel pump out, drill it, and get it back in....but having a gauge is pretty key so you know what's actually happening instead of guessing
Old 03-07-2013   #108
Trogdor
Trogdor's Avatar
Re: From ashes
I'll look in to it out of curiosity. But honestly, I'm not looking to make any more power for a long time. If I could squeeze a couple more out of this 20 minutes worth of work, it's probably worth it. But I'm very happy with where its at right now
Old 03-07-2013   #109
timschot
timschot's Avatar
Re: From ashes
Keep in mind, with super high pressure, you can pretty easily pop the return line off the nipple at the tank. Happened to me twice before I did the drill mod. Hasn't happened since. I was reluctant to just put a tighter clamp on, because I'd rather have it pop off there than in the engine bay.
I would do what Scheides said.. put a fuel pressure gauge on there (or have Ron do it) and if it's crazy high, do the drill mod and see if it helps much. It will definitely help, but it might not be enough with the w400's flow at idle.
2008 GSR SSS WW
RS motors built
Old 03-07-2013   #110
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: From ashes
fpr and drill that shit out bobby, better safe than sorry. Welcome to the world of modding haha
Old 03-07-2013   #111
Trogdor
Trogdor's Avatar
Re: From ashes
Thanks Tim, ill keep that in mind!
Old 08-07-2013   #112
Trogdor
Trogdor's Avatar
Re: From ashes
Well, here's a bummer update.
About 2 months ago now I took the car down to Ron's to have said ignition problem looked at, and it turns out that noise that we all thought was piston slap, was something more severe. So MAP has had the car down to short block for a while now. Cylinder #3 was fuel washed. The injectors have been sent to ID for inspection. They called me this morning and said that nothing is unusual that would indicate the injectors were the problem. One was flowing a little low, but still within Bosche's standards. FML
Old 08-07-2013   #113
Re: From ashes
That sucks to hear What are you going to do with it now?
Old 08-07-2013   #114
93gtpeater
Drives: cbr 1000rr repsol
Re: From ashes
Ouch. Who built the motor?
Old 08-07-2013   #115
Fran05
Drives: DSM
Re: From ashes
So whats wrong with the motor?
Old 08-07-2013   #116
Re: From ashes
So what was discovered regarding the noise, spun bearing?
Old 08-07-2013   #117
Re: From ashes
Yikes...
Old 08-07-2013   #118
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: From ashes
Hmmm, this sucks
Old 08-07-2013   #119
dsmreck
dsmreck's Avatar
Drives: 98 gsx
Re: From ashes
yes it does suck. I too want to know what a washed cylinder would do
Old 08-08-2013   #120
93gtpeater
Re: From ashes
A washed cylinder would be a cylinder with no/little compression. A washed cylinder is shiny and has no cross hatchings.
