Old 09-16-2013   #28
Tachyon
Tachyon's Avatar
Drives: Icarus
Re: Slipping Clutch/ Contamination Issue
I personally had a dragging issue with my mismatched setup. Just make sure if you're running an ACT clutch setup, that you have matching components.
As did I. I would also recommend match components.
While mine was the 2900 (with 7lb Fidanza FW) rather than the 2600, the thing would never slip regardless of the abuse. I've done full disc with springs, sprung 6 puck, unsprung 6, and chewed though 3x 4-pucks at about the 450 TQ level and it always held and held.
I even had to launch in 5th gear all the way from South Minneapolis down to Prior Lake because the gearbox grenaded and that was the only gear left to choose. Still held without slipping!
Sucks you're having such shit luck with you setup.
-Sebastian Vettel
Tags
clutch, contamination, drive train issue, slipping
