Old 09-21-2013   #5
b00sted_spyder
Re: No spark on 2 and 3
It is definitely not a power transistor/ignitor issue. I just tested the brown/red wire that runs to the ecu pin 23 which is for cylinder 2 and 3 on the power transistor connector. It reads .04-.05. I'm assuming it should be around 12 volts? The black/blue wire runs to ecu pin 10 which is for 1 and 4 shows 12 volts. I ran through the wire and did not find it cut or anything.
