Old 10-18-2013   #11
Re: Project Lex
Some more pics. I think I'm done with the passenger and driver side wires. One thing I may not have mentioned is I've removed my ABS, so the ABS fuse box and associated wiring is removed from the driver side. So the wire you see that I ran in that wheel well is just the brake reservoir sensor.
Passenger Side:
here you can see I extended the alternator cable about 8" or so and snaked it (and clamped it) around the bottom side there
the next few pics you can see I just used black zip ties to secure the loom. I think I'm going to go back and add a 2nd zip tie to every spot just for redundancy in case one were to break. I also had to extend that wire that runs back into the engine bay near the firewall, must be for A/C or something.
How it looks in the engine bay now.
Driver Side:
Had to extend the brake reservoir wire (forgot how much) Probably could have extended it a little more, but I think it's probably fine.
