Old 01-13-2014   #1
dsmreck
dsmreck's Avatar
Drives: 98 gsx
1g 7 bolt 2.4 6 bolt head long block
up for sale or trade is my last years build. 1g 7bolt 2.4 block oe 2.4 crank all inspected by motors by gosh. 87mm wiesco pistons and rings gaps are 20&24
eagle h beam rods, acl race bearings, arp mains, rod and mains have .0025 oil clearance. piston to wall is .004 block surface was decked for mls gasket. forward facing oil filter housing, new mitsu front case and mitsu balance shaft delete. arp head studs.
head is a 6bolt port and polished 3 angle valve job. ferrea 6800 series valves bronze valve guides surface was decked for mls gasket.
head will come with 3g lifters, no cams or springs unless you pay extra for my bc springs and titanium retainers, and bc 280's.
I prefer to sell as a long block and will give everything I have for a seven bolt with it. i.e. crank sensors etc. if you buy cams and springs it will be a drop and go setup, if not i will have to separate the head to disassemble as the valves will fall onto the pistons.
looking for a good 6bolt 2.0 to build my drag engine for this year.
i'll entertain reasonable offers and would prefer you to pick it up as i assume shipping will cost more than that, and making a crate to hold this thing solid would be fun at best. looking to get $3000 for everything $2700 without cams and springs. obo text call 218 259 o576
ID:	14118   Click image for larger version
ID:	14119   Click image for larger version
