Old 01-21-2014   #11
Re: 2007 Lotus Exige S
Not using Dzus for a wing, that would scare me.
There are 3 studs coming out the bottom of each mount, each one is 6mm diameter with a 10mm nut. The center studs also connect to a brace inside the trunk. So I guess to remove it I just need a 10mm wrench for each of the 6 nuts and I can leave the trunk brace in place all the time.
The clam is drilled and wing in place, just need to get the trunk brace installed. The hatch has about 1/2" clearance when opening, and the wing is mounted nearly at the back of the car. Close fit.
Tags
carbon fibre errrthang, jdm wiper
