Old 02-06-2014   #11
b00sted_spyder
Re: Very Bad Vibration
Originally Posted by mark4g63t View Post
Driveshaft is already out. Would it be easiest just to pull the diff?
Or I can just drop the whole rear end again
Mark the teeth of the ring gear?
Leave the differential in it. It has to be bolted up to how it would be setup. I've never been underneath an awd dsm so I don't know how tight the space is. But if you can't get the cover off, you will have to drop the rear end off.
Yes, mark the teeth of the ring gear. As you turn the pinion, it will make contact with the ring gear and show you the pattern.
