Old 05-12-2014   #8
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: dsm link v3 tuning help :/
I'm off friday, i could help then if needed.
Make sure the car is boost leak tested, you have tools and fluids on hand.
Mod list.
272 cams
adjustable cam gear
2.3
1600cc injectors(running gas and 450cc now just while I get the hang of things)
Gm maft.
V3 link
3 exhaust
all the supporting mods.
Hx35 7blade (sitting on the shelf for next summer )
Basically ive just driven it around the block and adjusted maft comp sliders based on the recommendation of link.
I set the base settings to where they should be. But in all honesty im sure I may have missed a few values that I need to log.
I wish I could afford db.
Im not looking to put down max hp/torque
just want it tuned reasonable and driveable.
Next summer I plan to go balls to the walls. But this summer I just want to get the basics down. Learn to tune properly.
Thank you guys for replying btw. The ecmlink forum is pretty rough. Im not a master tuner so it feels like they look at you as if you were a 420a guy asking why you cant swap in a 4g63t :/
M1L3S is offline   Reply With Quote
