Old 06-06-2014   #11
Re: Potential Buy 1997 GSX
So far im not worried about what im seeing with what's going on with the car or with what im reading in the wiki and helps on ecmlink.
Im not doing any wot pulls nor have I done any. Ill post logs of my trip in to work when I get home.
Im pretty sure I have the injectors and idle dialed in. I am also now pretty sure I have the "cruise" logs I needed to set up the combft sd 've table. I reviewed all 6 logs I did comparing all of them and choose the one I believe to best suited to use for the adjustment.
I am going to load those adjustment points before leaving work.
And then go log some more and then do comparisons when I get home.
According to the wiki after I have the"cruise" part set up. The only way to get into the higher hz is to do some
