View Poll Results: Block color?!
Semi-gloss black 5 100.00%
Green "Metallics" *pics of can posted* 0 0%
Cummins beige 0 0%
Purple 0 0%
Cast Iron 0 0%
Metallic Gold 0 0%
Paint By Numbers 0 0%
Multiple Choice Poll. Voters: 5. You may not vote on this poll
Old 06-11-2014   #11
DSMINMN
Mitsus for days!
DSMINMN's Avatar
Drives: '08 Chrysler 300C
Re: 95 Talon TSi AWD
I've been doing some thinking lately and have run into a minor problem. Air flow to different coolers/devices. The intercooler up front won't be a big deal, the ducting for my air filter will be fine (passenger side inlet) but what about that transmission cooler. There's no way it'll sit in the factory location. Maybe if I turn it to an angle but then what good is that.
My idea for a solution: Chrysler, as terrible as they were with transmissions made a helluva cooling setup on the automatic Cummins trucks. The cooling went as follows: trans. out/hot, heat exchanger (fluid to water/coolant cooler), to front air cooler then finally back to the trans. in/cool.
What does everyone think of this idea? Using the coolant as a source of cooling for the transmission fluid rather than an air cooler?
