Old 07-17-2014   #11
Well back to the build thread.
"Agent Ezzard" from tuners (previous owner) had left the DMV after an hour with things to do. With out him or I remembering to load all the settings in my laptop, me not knowing anything about speed density, running an wide band instead of a front O2 sensor, having not used dsmlink in 7 years, and having nothing setup in my laptop correctly other then the downloaded software and drivers for v3. Leads me to getting a crash coarse in tuning, thankfully Jery1234 on ecmlink forums has been a huge help with basically walking me through set up and tuning my car.
So after a few weeks of setting up, cruise logs, wot pulls etc. It became quite clear that in the South Carolina heat which stays in the 90+ range for almost 4 months straight and two of which are usually 100+. The cars cooling system was not going to cut it, i was seeing regular temps at 223-229 while cruising around.
So after long debate on what's the best first step. I took the advice from members here and went with a new 180 thermostat, 15% coolant, distilled water, and water wetter.
To start with i drained the system and flushed it out. Pulled the thermost to find that the previous owner cut the entire middle section out of it and basically was just using it as a gasket. After that did an Oil change using Mobil 1 5w-30w and stuck with the same type/brand filter that was on the car. While I was under there I noticed the flywheel inspection cover is missing and I quickly noticed why the previous owner mentioned he just replaced the starter. Flywheel teeth are all chewed up so a new flywheel is now added to the list of things to replace. And drained the oil catch can.
So finished up, warmed up the car and went for a drive. Temps were sitting around 206-213 for the short trips around town... temps were lower but still no where near where they need to be.
First day back to work temp was 106 outside and coolant temps were at 229 by the time I got through all the speed bumps and parked the car at work.
So something had to be done. Back to the boards I went with the question....do I get fans or do I get a radiator.... Once again took the advice of members here and ordered up a mishimoto xline radiator and radiator cap. The hope is that the 25% larger radiator coupled with the 1 stock fan will solve the issue.
I had a week to wait till the parts arrived from "map". In the mean time its been raining a lot and temps have been in the 70-80's... and all logs show 193-206 temps when outside temp is below 90. But I know this is south carolina and temps won't stay this low so feeling confident in my first major purchase for the car.
So walking threw the door yesterday found this waiting for me.... woot my first upgrades.
ID:	14574   Click image for larger version
ID:	14575   Click image for larger version
ID:	14577   Click image for larger version
ID:	14578   Click image for larger version
ID:	14580   Click image for larger version
ID:	14581   Click image for larger version
