View Poll Results: Where do I go from here? (now that all of the children have grown up...)
Build the X 17 56.67%
No one wants a $60k evo with high monthly payments, get out now and buy a 9. 13 43.33%
Voters: 30. You may not vote on this poll
Old 07-21-2014   #1
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Simple: See what's in-stock immediately available for wrenching this week
One side-note: Sometimes when manifolds get ported they slightly warp due to heat and the flange face isn't as true as it was from the factory; the white gasket allow for more squish than the OEM gasket does. Cobb had this issue with a ported IM (MAP Rev2) and the OEM gasket wouldn't seal it.
Well that was my thoughts as to why the leak is there, because I got a MAP rev3 since last time it was isntalled. So I assumed the white gasket I had was formed to the OEM manifold and after the porting, the surface changed slightly and it wouldn't seal.
If they have the white one in stock I will go for that I suppose. It's not the end of the world to do the IM twice I guess. And if it has more "squish" than OEM, that is probably a good thing.
Tags
casual mention of an evo, cold little murlo, daves sexcapades, flip flop, flip flopppp, hotdog crank polishing, manifold butthurt?, sexy time.
